For some unknown reason there are specular highlights in the, for example temperature 2D guide geometry. That seams like a really bad idea since they do nothing more than make it impossible to view the guide geometry from certain angles.
Is it possible to change or is this considered to be a bug/feature?
Disable "specular" in voxel in fluid guide geometr
2411 2 1- xtimmyx
- 166 posts
- jason_iversen
- 12527 posts
This has been mentioned before; everyone finds this a little frustrating. SESI should definitely be assigning a constant shader to the Plane visualizations.
In any case, as a work-around you can hit ‘d’ and bring up the Display Options and in the last page, turn off Specular highlights for everything.
- xtimmyx
- 166 posts
