I am trying to create an effect where just the edges of my object with respect to the camera emit particles. I can delete by normals to get just the edges, but I am looking to get a smooth falloff to drive particle emission.
I am trying to color my points based on their orientation to the camera and then use the point colors to drive the particle emission rate. I can see how this is done in a shader context, but in geometry context I am not sure how to calculate the point normals with respect to the camera.
Any ideas or other methods of doing this?
Emit Particles based on Normal Angle from camera
4970 2 1- aswaab
- 214 posts
- brianBurke
- 192 posts
Hi aswaab. By knowing how to do this in the shading context, you're pretty much all the way there. You can use the same tools.
I attached a simple example with a VOP SOP. The only part which I think is not self explanatory is getting the camera position into VOPs. You can do this with a Parameter VOP of Vector type with the Translate Parameter of the camera referenced into it.
Good luck dude.
Good luck dude.
- aswaab
- 214 posts
