How does pcexport work?
   3016   1   1
I am trying to use pc export to write P back to a point cloud. The point cloud is being read in using op:`opinputpath('.', 1). The questions I have are:
1. Should pcexport work in this case?
2. If I pcexport “N” for a point in the cloud, the next time that point is found, will I get the value of N that I pcexport?
The code below is attempting to find the closest point, but can't use cloud points that have already found.
sop
proximity_reorder(
string file = “op:`opinputpath('.', 1)`”;
float radius = 0.3;
int maxpoints = 1000;
vector n_check = {-99,-99,-99};
vector n;
int handle = pcopen(file, “P”, P, radius, maxpoints);
while(pciterate(handle)) {
pcimport(handle, “N”, n);
if(n != n_check){
int chk = pcexport(handle, “N”, n_check);
pcimport(handle, “P”, P);
pcclose(handle);
I don't think VEX will expand backticks.
