A very strange problem.
3182 5 0- flyingc
- 160 posts
- probbins
- 1145 posts
- probbins
- 1145 posts
Just another point, put a high value in the Particle Radius, say 2 and watch what your particles do. Very interesting. Then pipe in a Particle Fluid Surface sop below your Popnetwork sop.
“everything is coincident”
- flyingc
- 160 posts
- tamte
- 8635 posts
it is working here exactly the same with or without attribute1 pop in stream
the one difference can be if the attribute created with attribute1 pop had exactly the same name as some parameter in voppop1
which is not the case in the file, but if the attribute was called drg1 instead of drg, then it would override drg1 parameter in voppop and it would behave differently
not sure if this is your problem or maybe you can post a file with one pop stream working and one not, to help you find the problem
FX Supervisor
Method Studios, NY
FX Supervisor
Method Studios, NY
- flyingc
- 160 posts
