maybe I'm going about this all the wrong way, but I'm wondering if there is a way to creep particles along a curve inside a forloop.
I have n number of curves, which I want to randomly run particles down over time.
my first thought was to do a foreach loop on the number of curves, with a simple particle simulation inside the loop that had an impulse emission driven by the FORVALUE. But it seems like the particle simulations all end up identical.
Am I over complicating things? is there a better way?
Running particles along a n number of curves
4479 4 1-
- Allegro
- 696 posts
- old_school
- 2540 posts
POPs can't be put in a foreach loop.
What you can do is separate the curves out one per leaf and then use a POP Merge SOP to reference the original pop network.
Heavy use of opdigits() allows you to build network bits that can be quickly copy-pasted and auto-configure themselves.
If you want you can wrap the repeatable network bits in to a digital asset.
- wolfwood
- 4350 posts
Allegro
I might be over simpilifying but the Creep POP has a prim attribute. You randomly pick which curve the particles are on with that.
- Allegro
- 696 posts
- anon_user_46661527
- 12 posts
