Hi everybody,
I have got a little problem with the polyextrude SOP, basically I want to extrude an edge, so what I do , I select an edge (of a poly box for example) in the 3d view and then right click to complete, but nothing happens ! Any ideas ? I probably do something wrong, but I can get it work
thanks in advance
Julien
Polyextrude problem
4323 6 0- Undertaker
- 113 posts
- george
- 276 posts
Hi Undertaker,
If is a default Box that you are putting down? The first thing that comes to mind is that perhaps you've made a box out of a mesh. PolyExtrude works strictly on polygonal geometry. If you middle click on the Box sop, it should tell you how many primitives you have – on a box you should have 6. (If it were a mesh, you'd have 1).
Hope that helps,
George.
Hope that helps,
George.
- Undertaker
- 113 posts
- george
- 276 posts
Does extruding a face work? So here are the steps that I'm trying that work for me:
1. Start fresh Houdini
2. Go into SOP (model)
3. In the Viewport I put down a Box
4. I hit ‘tab’ and PolyExtrude
5. I switch to edges from the left side toolbox
6. Select one edge
7. Hit RMB
I then get the handle show up and I can extrude. Is there anything different from what you are doing?
Thanks for helping me try to track this down.
Take care,
George.
6. Select one edge
7. Hit RMB
Take care,
George.
- Undertaker
- 113 posts
- george
- 276 posts
- Undertaker
- 113 posts
