I have a volume object with a basic volume material. I want to fade it along the Y axis, getting thinner and less dense as it goes up. Or even better, as it ages.
How do I change the density? Is it something to do with the volume mix node?
Or could I transfer alpha attributes from points to a volume?
Fading Smoke
7559 5 3- Soothsayer
- 861 posts
- xtimmyx
- 166 posts
- old_school
- 2540 posts
I think he wants to alter an already generated volume.
You can use a Volume Mix set to user mode and use something like:
$V * (1-$BBY)
or add a ramp parm and index in to the chramp() function with $BBY to have a ramp control the fall-off
or set it to multiply and create a second volume filled with increasing density and composite the two.
or use a Volume VOP SOP and do it in there. Volume VOP SOP works on voxels instead of points. Just do your bby stuff in there.
$V * (1-$BBY)
- Soothsayer
- 861 posts
- old_school
- 2540 posts
Oh I thought you were in SOPs… In SOPs you work with a single field at a time. Opacity is usually a color which requies three volumes but sure you can apply a Volume Mix SOP to all three and scale the voxel values by that expression.
$V is the current voxel's value. By multiplying it by $BBY you are linearly reducing the voxel values as you move up in Y in the volume primitive(s).
I think you mean opacity from within a shader. You can read in any volume primitive in to the surface shader as a parameter by it's name in SOPs. It's probably best to create another volume that is the same size and location that has decreasing values from 1 to 0 then in your surface shader, multiply the volume that you are using to shade (probably density if it is smoke).
- pelos
- 617 posts
