Hi everybody.
1. how can i smooth a geometry in houdini without adding new vertices to the object. something like auto smoothing in 3DS Max. i tried smooth node but it is not what i want.
2. How can i bound an object inside another one, so that when i, for example move the inner object, something like the pic below happens. creep can do this to some extent but it is not the exact same thing. any suggestions?
3. In blender you can select the whole geometry and then remove all the vertices that were very close to each other leaving just one of them–it was called remove doubles–. How is this done in Houdini?
modeling questions
7907 12 0- ramin22
- 70 posts
- ragupasta
- 349 posts
1. Add a facetSOP and use the cusp polygons slider.
2. Not 100% sure what you are asking for here, but try adding a subdivideSOP, but make sure your editing is done before this node. Like have the display flag set to the subdivide, and have the previous node you will be working on templated.
http://i24.photobucket.com/albums/c44/ragupasta/modeling.jpg [i24.photobucket.com]
3. If you use a dissolveSOP to remove edges, there is a toggle switch inside this node called “remove inline points”. This should do the trick. If not you will need to select those points and use a deleteSOP on them.
- danBode
- 50 posts
- rdane1010
- 120 posts
- ramin22
- 70 posts
1. i couln't use facetSOP for that. are you sure it can smooth the object? what i understand from the help is the exact opposite.
houdini help facet sop: “Cusp Polygons: Creates hard edges between adjacent sides.”
but thanks ragupasta cause apperently mantra does the auto smoothing automaticly (am i right?) and i was wondering how to harden surfaces and facet does that.
how can i turn off the auto smoothing?
2. i want a boundary or border around my object which won't let the object inside it move out of it. like the picture. if you worl with creep you'll get what i mean. but the problem with creep is that it just bounds the object in 2 dimentions and it is projecting not bounding.
3. yes Fuse is what i was looking for. thanks Dan
- ramin22
- 70 posts
- edward
- 7754 posts
- ramin22
- 70 posts
- edward
- 7754 posts
- ramin22
- 70 posts
- ragupasta
- 349 posts
- orr
- 98 posts
- ramin22
- 70 posts
