How to blend two ramps
   3762   2   1
Hi Evbody,
I have no idea how to approach the following issue, maybe I could get some advice:
I have two “simple ramp” shaders, both with slightly different base colors. The are assigned to different groups on a single mesh, and I need to add a smooth transition/blend between the two.
Thanks in advance for all suggestions.
Greg
Maybe you could set the colors as point colors on the mesh, and then use that in the shader?
eetu.
Thanks eetu,
I'll try it tomorrow.
Greg
