I'm investigating Houdini for audio processing and synthesis using 3D shapes (think Shape controlling Sound, rather than Sound controlling Shape). Please could you point me to any existing resources about this? I'm prepared to write code to interact with the geometry data, but I don't know where to begin. I'm new to 3D graphics, but Houdini seems very good for this sort of thing.
To start with, I thought I'd just look at evaluating the X,Y,Z coordinates of a point on a curve, with arbitrary values of U, then using the X,Y,Z to control something externally.
Any comments greatly appreciated!
Audio and MIDI from 3D shapes
7679 5 2- merryberry
- 1 posts
- edward
- 7724 posts
This book might have material on that:
http://www.andrew-lowell-productions.com/andrew-lowell-productions/resources.html [andrew-lowell-productions.com]
- dinkleberry
- 48 posts
merryberry is now dinkleberry.
After some more searching, I found the essential info in the online documentation:
http://www.sidefx.com/docs/houdini10.0/expressions/primuv [sidefx.com]
http://www.sidefx.com/docs/houdini10.0/expressions/primduv [sidefx.com]
http://www.sidefx.com/docs/houdini10.0/expressions/normal [sidefx.com]
http://www.sidefx.com/docs/houdini10.0/expressions/curvature [sidefx.com]
I'm very pleased!
But, I see that these functions are not yet implemented for Python… any ideas when this might come?
edwardThanks for the reply. I'd seen that earlier, I will probably get a copy later.
I'm very pleased!
- edward
- 7724 posts
- dinkleberry
- 48 posts
- andrewlowell
- 537 posts
sounds like a job for the geometry chop. Just read that into CHOPs and you have a curve representing the coordinates of your line or whatever other geometry you might have.
Once it's in CHOPs is just pure data, and can be resampled, or turned into, or used for controlling whatever else you'd like, such as generated synthesis or MIDI
