velocity -= <<0,abs(noise(position *0.09)*10),0>>;
this is maya mel for controlling particles fall.
how should I do, could make the same effect in houdini particles?
particle driven by script control. (tranfer MEL to Hscript)
3017 3 1- dim1984kimo
- 84 posts
- pclaes
- 257 posts
put down a vop pop and have a look at the nodes, you have all the building blocks you need there to rebuild that expression.
A few extra ones you might need are:
vectorToFloat
floatToVector.
Just as a simple example:
connect the global incoming velocity to the global outgoing velocity.
Now insert a multiply node inbetween. Create a parameter node and also link it in with the multiply. Go out of the vop pop, now you have a little slider control to multiply the velocity….
explore the other vop operators.
vectorToFloat
floatToVector.
- Antoine Durr
- 321 posts
pclaesYou could also just use a velocity POP. Place into each field (substituting the appropriate $VX, $VY, or $VZ): $VY-abs(noise(vector3($TX,$TY,$TZ) * 0.09)*10)
Of course, the noise calculation will be different in Houdini than Maya, so the end result will inherently be different.
– Antoine
- dim1984kimo
- 84 posts
