The copy SOP offers a lot of flexibility in changing parameters and attributes but I want to avoid heavy geometry so I want to achieve the same using instancing.
As I understand instancepoint() can only be used to change shader parameters.
The render attributes pscale and orient allow me to change uniform scale and rotation.
But with the copy sop I can make a variable and drive the switch. I love that!
How could I switch instances randomly?
Question relating to instancing
2719 2 0- Soothsayer
- 859 posts
- logon
- 6 posts
- tamte
- 8554 posts
Soothsayer
http://www.sidefx.com/docs/houdini10.0/copy/instancing [sidefx.com]
last two lines have answer to your question
so basically use
either delayed load shader
or one subnet OBJ with different OBjs inside and use pointinstance() to control their display parameter to randomly display only one of them
example file for the second method
FX Supervisor
Method Studios, NY
FX Supervisor
Method Studios, NY
