Attrib Reorient surface node tricky parameter
   2117   2   0
I was playing with the Attrib Reorient surface node and looked into
Houdini help on the subject:
I found that they use ‘orient’ parameter created in the Attrib Create surface node:
Everything is fine and ok. Unless you change the parameter name from orient to something different say ‘foo’ or whatever. Since that the teapots do not obey at all:
The question is whether the ‘orient’ is specific and something unique?
I did not find any reference on it throughout Houdini help
orient is special
http://www.sidefx.com/docs/houdini10.0/copy/instanceattrs [sidefx.com]
Thank you!!!
