Very Dark Interface
2503
4
0
cgrokr
Dec. 29, 2009 2:37 a.m.
I have installed houdini 10 Master. I have GE Force 9400 Nvidia Card with I GB of memory. CPU is intel QUAD 2.33 GHZ with 2GB of RAM. My Houdini interface is coming quite dark, I can't even see the Menu Items. Kindly help….
cgrokr
Dec. 29, 2009 4:30 a.m.
I have installed latest version from the nvidia site but problem still persist….
edward
Dec. 29, 2009 1:52 p.m.
Try quitting Houdini and then find and remove your houdini10.0 directory. BTW, which Houdini version did you install? It should be an X.X.XXX number.
cgrokr
Dec. 29, 2009 11:44 p.m.
I removed the directory still problem persists, version is 10.0.295 and I am windows XP..
edward
Dec. 30, 2009 6:08 a.m.
10.0.295 is pretty old. Did this used to work for you? You could try the current production build (10.0.465). You're also sure that you found all possible houdini10.0 directories on your hard drive right?
