hi,
I'm currently looking into “Mantrarogram Procedural” through the mantra_program procedural shop.
I would like to use a python script as a Program Procedural that will then create several child procedurals, these could be either program procedurals or delayed load procedurals.
So far I managed to use a little python script to generate my geometry and write it to the stdout which is then picked up by mantra. I can also write out the geometry to disk as a .geo file.
I am unable to get child procedurals working through the Mantra: Program Procedural shop.
Ideally I would want to be able to write my own string into the ifd file, but I do not know if this is directly possible from within houdini. (I would like to avoid having to post process ifd files with a script.)
I would really like the delayed load partitioning to happen at rendertime, as in I would like to avoid creating a pre-renderscript that puts down 1000 geo nodes with 1000 delayed load shops attached to them. I know how the ifd command is built up and I would simply like to write it in the ifd directly.
at the moment the ifd section with the procedural looks like this:
ray_start object # {
ray_transform 1 0 0 0 0 1 0 0 0 0 1 0 0 0 0 1
ray_procedural program program “/opt/hfs10.0.430/python/bin/python /home/pclaes/houdini10.0/scripts/python/makegeo.py”
ray_property object name “/obj/geo4”
ray_end # }
makegeo.py should generate a bunch of:
ray_transform 1 0 0 0 0 1 0 0 0 0 1 0 1.51268315315 0 0 1
ray_procedural -m -0.850650846958 -0.894427359104 -1 -M 0.850650846958 0.894427359104 1 file file “/home/pclaes/houdini_rnd/procedurals/test_01/ifd_geo/test_sphere_0001.geo”
ray_end # }
ray_procedural -m -0.850650846958 -0.894427359104 -1 -M 0.850650846958 0.894427359104 1 file file “/home/pclaes/houdini_rnd/procedurals/test_01/ifd_geo/test_sphere_0002.geo”
ray_end # }
ray_end # }
So is there any way to write into the ifd file from within houdini? Or to generate nested program procedurals from within houdini?
I have briefly looked at the possibility of doing it through the HDK, but would like to know if it is at all possible from within houdini with python.
http://www.sidefx.com/index.php?option=com_forum&Itemid=172&page=viewtopic&t=13558&postdays=0&postorder=asc&highlight=ray_procedural&start=0 [sidefx.com]
and
http://www.sidefx.com/docs/hdk10.0/hdk_vray_procedural.html#HDK_VRAY_Procedural_Intro [sidefx.com]
seem very useful.
Any help appreciated, even if it is a straightforward redirection towards the HDK or the clusterThis procedural.
mantra program procedural in python, calling delayed loads
3678 2 1- pclaes
- 257 posts
- mrice
- 89 posts
- pclaes
- 257 posts
thanks, I had not considered soho yet. I will look into it.
