I have a model that I have been projecting a few different textures on using UV Project in Houidni 6.0. Only the front and head currently have UVs projected and textures assigned, the rest of the model is still grayshaded and the specular highlight option is turned off.
I notice some artifacting when I dolly in or rotate the model in the viewport, protions of the surface become clear and distort a bit. The model renders just fine though. I was curious to know if this is a common OpenGL or graphics card issue(I am using an NVidia card). It does not really affect my work thus far, it s just sort of weirdly distracting…anyone else notice this or am I just lucky… :shock:
Texture problem
3680 3 1- anneh
- 9 posts
- tallkien
- 225 posts
- deecue
- 412 posts
yea, talkien is right..very common with nvidia cards..
set your clipping plane to .1 in your viewport display.. make sure to save that as your default setup. then create a new camera and go to your camera param. and set it to .1 in there and use the drop down menu to save as temporary default. now when you create new cams or new files, it should not revert back to clipping again.
hth,
dave
hth,
dave
Dave Quirus
- anneh
- 9 posts
