startup errors
   7068   3   0
hi . .
i get these errors ..
then it opens but there are missing toolbars , icons .
File “opdefDriver/hq_render?PythonModule”, line 3, in <module>
File “C:\cygwin\home\prisms\builder-new\Nightly10.0\dev\hfs\python\lib\urllib2.py”, line 92, in <module>
import httplib
File “C:\PROGRA~1\SIDEEF~1\HOUDIN~1.528\python\lib\httplib.py”, line 71, in <module>
import socket
File “C:\PROGRA~1\SIDEEF~1\HOUDIN~1.528\python\lib\socket.py”, line 45, in <module>
import _socket
ImportError: DLL load failed: Devingen bağlantı kitaplığını (DLL) başlatma işlemi başarısız.
Could not initialize the shelf python context: error: DLL load failed: Devingen bağlantı kitaplığını (DLL) başlatma işlemi başarısız.
exception: ImportError
details: Traceback (most recent call last):
File “<stdin>”, line 1, in <module>
File “CPROGRA~1/SIDEEF~1/HOUDIN~1.528/houdini/scripts/python\shelfutils.py”, line 8, in <module>
import assetdownload
File “CPROGRA~1/SIDEEF~1/HOUDIN~1.528/houdini/scripts/python\assetdownload.py”, line 5, in <module>
import urllib
File “C:\cygwin\home\prisms\builder-new\Nightly10.0\dev\hfs\python\lib\urllib.py”, line 26, in <module>
import socket
import _socket
import urllib
import socket
import _socket
import urllib
import socket
import _socket
import urllib
import socket
import _socket
Could not initialize help system: error: DLL load failed: Devingen bağlantı kitaplığını (DLL) başlatma işlemi başarısız.
File “C:\cygwin\home\prisms\builder-new\Nightly10.0\dev\src\houdini\help\houdinihelp\__init__.py”, line 5, in <module>
File “CPROGRA~1/SIDEEF~1/HOUDIN~1.528/houdini/scripts/python\wikiparser\textify.py”, line 4, in <module>
from genshi.core import Namespace, START, END, TEXT
File “Ccygwin/home/prisms/builder-new/Nightly10.0/dev/hfs\houdini/scripts/pythonlibs\genshi\__init__.py”, line 29, in <module>
File “Ccygwin/home/prisms/builder-new/Nightly10.0/dev/hfs\houdini/scripts/pythonlibs\genshi\input.py”, line 19, in <module>
File “C:\cygwin\home\prisms\builder-new\Nightly10.0\dev\hfs\python\lib\xml\parsers\expat.py”, line 4, in <module>
By any chance, do you have any Python environment variables set? (i.e. PYTHONPATH, PYTHONHOME, PYTHONSTARTUP).
If you do, try temporarily removing them and restarting Houdini. See if that helps.
Rob
Thanks,
i deleted PYTHONPATH var. and it worked ..
but Maya needs this var.
so i made a “.bat” file which contains
set PYTHONPATH=
hmaster.exe
now everything ok i think ..
but if you suggest a better solution i am listening
thanks again ..
Make maya.bat that sets PYTHONPATH to what Maya needs?
