I have a couple of copied objects which fall into surface points of another object.
I am trying to alight the normal of the copied objects to the ones in the surface points.
Does any one out there have a good solution ??
:roll:
Point normal blending
2211 2 0-
- Alfie_7
- 2 posts
- stronglikebool
- 28 posts
- Alfie_7
- 2 posts
The copy SOP show's good results when the objects are copied directly onto its surface, but in this case the instances land on the object surface.
I have tried using point to transfer the normals from the object to the instances, but the instances approach the object facing in the wrong direction.
I need the instances to align to the normals of the object as the approach it…
