"origin" return rotations between 90 and -270
   4860   6   0
I have some trouble with the origin expression.
I try to use it to retrieve the rotations values of an object in world space but it didn't return the expected result.
If you look my exemple, you will see that the rotations values retrieved with “origin”, are modified and are always between 90 et -270. But I need the real rotation angle. For exemple if I rotate the object by 360 I don't want to get 0.
Maybe I need to use an other function than origin, or maybe I need to recreate one. I was thinking that the only solution is to create a new expression function that will read all the parenting hierachy and compute the reals rotation values, but I'm not sure I could do it beter than the guy who have made the origin function (I'm not sure it's faisable)
Please tell me what you think.
Can I do it or is it not possible because of some mathematical problemes…
originExpressionError.hipnc (73.9 KB)
dealer2couleurs
It's not mathematically possible in general with 3D rotations. On the other hand, if you only have a 1D rotation, then it's possible but you will need to create your own method of doing it.
I don't know a lot the quaternions, but
don't you think I can compute for each transformation matrix the corresponding quaternions and use them to compute the final quaternion to rotate my object…
I had the feeling that it couldn't be done with matrix but maybe with quaternion…
you cannot do that through quaternions, you'll get just the final pose which is what you are getting
you can probably do this just by summing euler angles for all objects in upstream hierarchy (including pretransforms), but there should not be any other transform methods, like lookat, path, blend Obj, …
and they all should probably have the same rot order
FX Supervisor
Method Studios, NY
tamte
That can't work in general. I've attached a simple counter-example.
angles_summed.hip (63.8 KB)
you are right
it's not the same thing
FX Supervisor
Method Studios, NY
Tnak you for your answer,
As I was thinking, it's not a trivial solution.
I will continue with “origin” for now
