I'm a student new to Houdini 6 and I'm trying to model a tank for a project I'm doing. What I want to do is make some tracks that revolve around a curve I have already drawn to simulate the tracks movement. I have made an individual track piece and want to copy this all the way around the curve and then make each piece animate around this curve - I've tried many ways to no avail.
The only clear way I can see of doing it is by making an object for each track segment and them setting it to follow the curve path I have drawn. The problem with is is that I have about 40 pieces for each side, so when I want to move my tank I have to change each of the settings manually for 80 odd objects.
Is there a better way to do it?
Thanks.
Modelling Help
4464 6 0- Feenix
- 4 posts
- stevenong
- 1631 posts
Hi there,
Please search for answers to your question in this forum or over at odforce [odforce.net]. If I don't remember wrongly, there was also a mailing list thread & you can search through it here [sidefx.com].
Cheers!
steven
Cheers!
steven
- Feenix
- 4 posts
- edward
- 7715 posts
- Feenix
- 4 posts
- edward
- 7715 posts
- Feenix
- 4 posts
Thanks mate - thats just what I needed. The only adjustment I would like to make is to use more complex track pieces rather than tubes. This would work were is not for the normals. I need the normals of the curve the pieces are along to point upwards not outwards so that the track pieces apprear at the correct angle to the curve. For now tho I will stick with tubes but if anyone has any suggestions…
