Hm, i compiled my VRAY_Pocedural that works nicely on windows for linux and
it doesnt show up on linux. Same problem with hdk example stuff.
I tried both hcustom and manual build and set the files in the VRAYprocedural file. Is there anything special about mantra stuff?
VRAY_Pocedural on linux
2392 2 1- katisss
- 14 posts
- Infernalspawn
- 229 posts
when you compile the Vray procedural you get a mantra-shared object which you register in the VRAY_Procedurals file. you should be able to find out if it is loaded when starting mantra with the verbosity flag (-v <number>) try 5 as number.
But in order to have it show up in houdini and use it you have to build an interface otl (New Operator Type -> Shop Type –> Geometry/Procedural Shader) for this procedural. That otl should have the same parameters and parm-types as your coded procedural.
If I recal correctly make sure the Shader name is set to what your coded shader name is.
Infernal
Infernal
- pclaes
- 257 posts
I may be stating what you already know:
specifically for the mantra stuff, if I remember correctly you have to put your dso file in:
houdinix.x/dso/mantra
rather then:
houdinix.x/dso
I think you can change the dso path with an environment variable too.
Edit: only just saw your post on odforce too… so that's probably not it.
rather then:
houdinix.x/dso
