HBatch rendering. Expressions in output filename.
   3159   1   1
Hi
I am trying to render a frame range through HBatch with the command:
render -V -o renderOut$F.pic mantra1
My problem is that the frame range starts at 145 and do neither increment or decrement.
I also tried specifying the frame range with:
render -V -f 1 240 -o renderOut$F.pic mantra1
But same result as before.
//regards
Erik
EDIT: Solved it with a Hython script. Would still be fun/good to know why it didnt work through HBatch tho.
Drive, monkey, drive!
I think you might need to backslash escape the $F. ie renderOut\$F.pic
