Shader View?
3428 6 2- infinity_spiral
- 34 posts
Why the new mantra surface shader can't be seen in shader view?What happen to camera memo tool .Why futures like that don't work or missing?I think that shader view is important one and should work.It's Ok to remove old futures if they are replaced with new better ones but this is not the case with those two.
- malexander
- 5161 posts
- aiworks
- 130 posts
- infinity_spiral
- 34 posts
- mzigaib
- 949 posts
- ikerr
- 168 posts
Greetings,
The next build of Houdini has some fixes for the Shader View. Try out that build and let me know if you run into any other issues. Note that not everything will work in the Shader View. Sub-surface scattering is one example.
With that said, I'd highly recommend using IPR for previewing your materials as it will give you a much higher quality preview. Setting it up isn't quite as convenient, I agree, but I think the benefits far outweigh the set up time.
–Ian
–Ian
Ian Kerr
3D Software Developer
- mzigaib
- 949 posts
