Hi!
What will be better for vertex data collection:
1. Iterate through all vertices of mesh.
OR:
2. a) Facet SOP with “Unique Points” option On.
b) Attribute Promote SOP with all vertices attributes promoted to points.
c) Collect the data as hou.Geometry.pointFloatAttribValues(attr.name())
UPD: I see one only problem here - point order are edifferent from source vertices order…
So, what do you think?
Thank you in advance!
[HOM]: vertex attributes data collector trik?
1997 1 0- vyudin
- 77 posts
- graham
- 1908 posts
I'd probably just iterate over all the prims/verts and get the info, especially since the other method is just going to give you unpredictable ordering. Though depending on what exactly you want to do with that data it might work out fine.
Another approach I'd consider is using inlinecpp to do the getting and analysis if speed was really an issue. It most likely would perform better.
