Program Crash
23657 26 3- SergVideo
- 50 posts
Houdini 11.0.547 (I tried also 11.0.548 and 11.0.511) crashes at start. (My system: Windows 7 x64, AMD Phenom II x4 955, ATI Radeon HD 3300 video with 8.782.0.0 driver - AMD Catalyst Package v10.10). When I roll back to 8.741.0.0 video driver Houdiny starts normally. What is at the bottom of a problem, and whether it will be solved? The matter is that I need to update the driver for for more stable work of my video editing program.
- Simon
- 2199 posts
- rafal
- 1449 posts
it could be related to this (ie, you may need to install vcredist_x64 and reboot):
http://www.sidefx.com/index.php?option=com_forum&Itemid=172&page=viewtopic&t=20729 [sidefx.com]
- Simon
- 2199 posts
- SergVideo
- 50 posts
Houdini 11.0.548 still don't work on new ATI driver. After I downloaded and installed Catalyst 10.12 (display driver 8.8010.0) Houdini becomes crashes on start. Installing vcredist_x64 don't solve this problem. Whether this problem in new versions of the Houdini is solved? (My system is described above).
- SergVideo
- 50 posts
- malexander
- 5161 posts
- SergVideo
- 50 posts
- malexander
- 5161 posts
- malexander
- 5161 posts
- SergVideo
- 50 posts
- cybermax
- 255 posts
I am just want to ask, If this problem has been solved in some newer version of Houdini.
I am using 581 and I want to ask, if I have to download newer version or if this problem remain???
edit: I have driver v8.801
https://vimeo.com/user3251535 [vimeo.com]
https://twitter.com/milansuk [twitter.com]
https://github.com/milansuk [github.com]
- hopbin9
- 100 posts
- SergVideo
- 50 posts
- hopbin9
- 100 posts
SergVideo
In Windows: Device Manager/Display Adapters/ (right click on your adapter)/ Properties. Then click on Roll Back Driver button on Driver tab. Also you can uninstall (Uninstall button) driver and install older version from ATI/AMD site.
Thanks, I went back to 10.9 drivers from ATI and everything is working again. I'm resisting the urge to go into a rant about the poor quality of ATI products… resisting…. arg…
- hopbin9
- 100 posts
- malexander
- 5161 posts
- hopbin9
- 100 posts
twod
Try installing Catalyst 10.9 manually. Sounds like the rollback may have rolled you back a bit too far.
I uninstalled Catalyst, and then threw the device manager uninstalled the display driver. Then re-installed Catalyst 10.9, and everything appears to be normal again. Houdini is responding nicely.
Thank you for the thread, cause this would have been a show stopper. No thanks to Microsoft for pushing the driver update, and no thanks to ATI for what ever it was they did.
- SergVideo
- 50 posts
Don't become angry strongly on ATI. I use for a long time their video cards and I have as a whole less problems, than my colleagues who uses Nvidia. As it isn't strange, I now with success work in Adobe Premiere and After Effects CS5 on ATI HD3300 with HDV. Well and drivers are an eternal sad song… Not about ATI only.
- cybermax
- 255 posts
SergVideo
I dont hate Ati only for drivers, Ati has really terrible support on their website. For eg. why they have two version of drivers(with and without OpenCL) and why they have only drivers without OpenCL in their old drivers archive. If I wrong, send me link for 10.9 with OpenCL.
I call this “f*ck with consumer” and when I have money, I buy “guess what”!
