Is there any sop that I can work out the distance between 2 pts.
e.g. I want to do an animation about the plant and the sun. The closer the sun is located to the plant , the sooner the plant is going to die. This means I need to find out the distance between the sun and the plant. Then I will use the chf expression to define how many frame that I need to do the “frame delay”. Am I right?
Please show me how?
distance sop?
3277 3 2- brucelay
- 313 posts
- tallkien
- 225 posts
- brucelay
- 313 posts
- tallkien
- 225 posts
http://www.vislab.usyd.edu.au/sidefx/houdini_video/by_topic/general/index.html [vislab.usyd.edu.au]
First one
Also check exhelp distance (simplest)
chf or a lag chop if you like
First one
