Point culling
3326 3 0- ashrafgh
- 6 posts
- rdg
- 401 posts
In VEX all points are computed a the same time : SIMD.
In my tries to remove one of the points within a specified radius - always both points were removed. I explained this with SIMD and used a pythonSOP instead.
I guess with enough procedural energy one indeed can get a VOPSOP network wired up to do this?
http://en.wikipedia.org/wiki/SIMD [en.wikipedia.org]
this is not a science fair.
- tamte
- 8556 posts
rdg
you can do it easily in VOPs if you delete point with lower ptnum, that way always only one from the pair gets deleted
however if you want to make sure that no other point is within specified radius then more iterations are needed (ForEach) because at every iteration only closest one is deleted
FX Supervisor
Method Studios, NY
FX Supervisor
Method Studios, NY
- rdg
- 401 posts
