1. clean install OpenSUSE 11.4 - x64 (one difference - ext4 FS. I have never use that before)
2. clean install Houdini 11..0.733 - x64
try to create some animation and “flipbook” - 2 black MPLAY windows and in console:
Warning: invalid .mplay_lock file detected
2 times.
When i try to render (render node with output to “ip”)
mantra: Could not open imager
ok. i try to start Mplay as “listen”
the same result.
What can be wrong ?
Firewall is disabled.
Internet is working.
I have never seen that error before. Some ideas ? (Searching give me only same errors on Windows)
Mplay troubles on Linux
5572 9 1- live_fx
- 160 posts
- malexander
- 5158 posts
- live_fx
- 160 posts
there no such files in $HOME/houdini11.0 dir..
I try to move houdini11.0 dir to another location (when houdini is launched) and start render again - the same result. And no any “lock” files in my $HOME dir - (only skype lock)
Sorry but i will try to reinstall OpenSUSE 11.4 back to 11.2 - because 11.2 was worked for a long time without problems. (and ext4 -> to ext3)
- live_fx
- 160 posts
- malexander
- 5158 posts
- live_fx
- 160 posts
- malexander
- 5158 posts
Ah. I have heard some bad things [opengl.org] about the new 270 drivers, especially regarding FBOs, which MPlay and Houdini both use. Why Houdini works and MPlay doesn't is a bit of a mystery.
- JColdrick
- 4140 posts
- live_fx
- 160 posts
JColdrick
I have to tried 270.41.06 few minutes ago - and Mplay work correctly.
But when i again install 270.41.19 - Mplay is again run with “blind” error.
I think that more than 270.41.06 update - is not necessary. As always with Nvidia linux drivers - the “new and last” not means good)
My card - 9800 GT.
My card - 9800 GT.
- malexander
- 5158 posts
