Hi guys,
how do i renaming a specific attribute in a specific column & row.
For example, i have a primitive attribute under (vertical) column “A”, which is also under a (horizontal) row 5, with a value of say 50.
How do i actually rename the value 50 into something else that i want?
Thank you and regards.
Renaming a specific attribute in a specific column & row
2048 2 0- twohardballs
- 38 posts
- tamte
- 8587 posts
you can use Attribute Create SOP
and fill in following parameters (according to your example)
Group: 5
Class: Primitive
Type: float (probably or integer or exact type of your attribute)
Value: value you want
OR
you can directly type/rename the values in Spreadsheet for any SOP node but that will lock the node so it may not be useful or maybe you don't mind
there are other methods but it really depends on exact needs
Group: 5
Class: Primitive
OR
FX Supervisor
Method Studios, NY
FX Supervisor
Method Studios, NY
- twohardballs
- 38 posts
