Shadows for PyroFX Shader
   4059   2   0
I´m trying to illuminate a volume that uses the pyro shader, the thing is that when i use Depth Map shadows no shadows are visible, opposite to raytracing. Im using a point light that is the only light source. In other post i read that dshadows are better for volumes is that right? Thanks!
NicoZ
To use deep shadows more efficiently, make sure it's a spot light framing the volume properly.
Cheers!
steven
stevenong
Cheers!
steven
Thank you very much steven, using a spotlight did the job, now i see the shadows
NicoZ
