setParmTemplateGroup on multiparm block parameters
   2275   3   1
Hi!
I'm trying to hide some parameters that are visible in my digital assert and are groupped in multiparm block with python.
the psedo code of that should be like:
n = hou.node(…)
g =n.parmTemplateGroup()
g.hide('readCloudProb#', True)
n.setParmTemplateGroup(g)
# I'm using ‘readCloudProb#’, because ‘readCloudProb1’ gives an error and ‘readCloudProb#’ is seen as parameter
Additional, after these changes, when I'm checking g.asCode() it seems to contain the code for parameter hiding, but this parm is always visible
This code works for parameters that are not groupped in multi[parm block. Why it does not work for multiparm?
node=hou.node('/out/mantra1')
a=node.parmTuple('/out/mantra1/vm_numaux')
a.hide(True)
this is one of the example for hiding multiparmblock block
I do NOT want to hide MULTIPARM BLOCK, but I want to hide a parameter (like float slider, that is INSIDE multiparm block).
Of course I want to hide it from all blocks of this multiparm.
Does somebody know answer for this question?
