hi,
i want to get shadow points ? can some one help me how to achieve ? I turned on Phantom and my object is not visible in render but i want to get shadow points, so that i can animate from these points.
probably hard to understand so here is an example link :
http://vimeo.com/12255503 [vimeo.com]
thanks
Asad
how to get shadow points
2298 2 0- asadkazmi
- 15 posts
- pclaes
- 257 posts
If you want what is shown into that video, you could scatter points on your object, then add a normal to them in the direction you wish to project them and use the ray sop to project them onto a grid.
This will give you a “shadow” – a shadow is nothing more than a projection. The interesting thing is the projection normal, read up on the ray sop and check out some examples for it.
- asadkazmi
- 15 posts
