A 48 hour game making competition called ludumdare just started a few moments ago.
http://www.ludumdare.com/compo/ [ludumdare.com]
I've been making a game for class at SMC for the past couple of weeks in houdini. (mostly as per hiptricks vol4)
Anyway, I thought it might be fun to try the same techniques in 48 hours to make another game for this competition.
I thought it would be even MORE fun if some other people were doing the competition in houdini, too!
So what do you say?
The theme is “Alone”
~Maitland
make a game in 48 hours
2931 1 2- twelveplusplus
- 194 posts
- stjohn
- 140 posts
This is an excellent idea, and a great place to show off the sheer amount of material you can generate in a very short time using Houdini.
The difficulty currently is getting the content into the game engine if you're using HD or Apprentice. Unless you have FBX export support, or a houdini geo reader on the engine/editor side, you'll be limited by what you can shove into a .obj file.
If you're using Escape or Master, that's not a problem, and all you need to do is make sure you're using FBX export so you can do multiple UV sets.
The best way to do it would be to have a lot of game-ready tools set up as HDA's so that when it comes time to actually enter the competition, you can spend the 48 hours most efficiently.
