Is there HOM to center a network at a specific coordinate?
Id like to be able to save a node/tile(s) coordinate and later go back to it.
I see theres a position method on nodes, but im not sure how to tell a network pane to center itself on it.
im currently using setSelected/setPicked on nodes, which takes me to
the correct network, but it requires that the network be homed manually.
tia.
HOM : goto a specific coordinate in the network
1899 2 1- sdugaro
- 380 posts
- graham
- 1908 posts
There is no way to center to a particular position, but if you are already using setSelected, you can use hou.NetworkEditor.homeToSelection() to tell your pane to home in on whatever is selected. Of course, you'll have to find the network editor you want to use but that's pretty easy.
- sdugaro
- 380 posts
