Z-Depth pass files Unreadable by Compositor
3453
6
0
Drex
Jan. 26, 2012 6:19 a.m.
When I try to get a separate seq for Pz plane (i tried tif, exr and pic seq with same results) in Mantra, i always get unreadable by AE cs 5.5, Combustion 2088 and Fusion 6.3 files. When i tried the same with Normal pass, i get a perfect readable file. It seems to be an issue only for Pz variable. H 11.0.812 here. Any suggestion? Thanx in advance.
eetu
Jan. 26, 2012 6:23 a.m.
My guess would be it's because Pz is a single channel (“grayscale”) and Normal is three channels (“color”)
Drex
Jan. 26, 2012 7:22 a.m.
Hi, Thanx for response. If that was the case… Any way to change that? Or any program to convert the files externally? I even can't open the files in Photoshop.
mickyblue
Jan. 26, 2012 11:03 a.m.
Hi Drex, You should know that the renderd files are normaly saved as a 32Bit float file, so they are not clipped limited or tonmapped! Maybe you just need to find the right spot in which your depth (grayscale) appears… send a test file!
Edited by - Jan. 26, 2012 11:18:37
Drex
Jan. 26, 2012 11:11 a.m.
OK Guys. I did this simple example including the HIP, one rendered frame, the Pz pass rendered file an N pass rendered file. Thanx.
Rings.zip (2.3 MB)
mickyblue
Jan. 26, 2012 11:42 a.m.
everything is fine! I saved an exr. and used the AE extractor. And indeed the images appers white befor you dont hit the right greyscale spot. In this case B=20 W=-9 hope that helps!
Drex
Jan. 26, 2012 7:58 p.m.
Thanx U Mickey, It worked perfectly as you said. But I still have that thorn on my feet… Why a Pz pass saved in a separated image is unreadable on Compositor?
