Right now i am using houdini apprentice version is it possible to
save hip file in ascii format if we purchase houdini master license
Sab
Ascii Format
6347 4 2- sabareeshrg
- 33 posts
- old_school
- 2540 posts
- sabareeshrg
- 33 posts
- old_school
- 2540 posts
HIP files are saved as a .cpio archive (similar to tar).
If you have an editor that can deal with binary data such as vim, then you can view the parts of the scene file that are written out as ascii data. Geometry is saved as binary data.
You can use the command line tool:
hexpand
usage: hexpand <hip_file>
-p: prepends the ‘cpio.’ prefix to the contents and dir files
hexpand will expand a Houdini scene file into a directory structure
that can be browsed and edited using standard tools, then collapsed
back into a regular .hip file using hcollapse
I don't know if this command is available to Apprentice users but you give it a try. It requires you to use a shell with the Houdini environment in place. You can open such a shell from Houdini's main menu.
hexpand
- sabareeshrg
- 33 posts
