hi,
Space W to wire/shade isn't working when in Quad (space b) mode. It only affects the selected viewport. Yes, I have Affect All Viewports turned on
Edit: Also, Space +RMB and selecting the menu item “Select Viewport” does not work. Space +n (lowercase) does work, though the RMB menu indicates a captical “n”
Falling back to H11 viewport fixes all this and it works as expected.
12.0.559 Linux 64bit
Peter B
BUG: Space W not affecting quad viewport
2058 1 1- pbowmar
- 7025 posts
- halfdan
- 599 posts
pbowmar
Yup. That's logged.
pbowmar
The hotkey display was in a dire need of minor modernization. As of H12, if you see “N”, then it just means pressing the “N” key, with no modifier keys held. If you see “Shift+N”, then it means that Shift and “N” should be pressed. The problem was that it was hard to see the difference between the “l” glyph (lower case L) and “I” glyph (upper case I), among other things.
I.e. it no longer goes by the glyph, but the keyboard key. Which is also the gold standard in all other UI libraries.
Halfdan Ingvarsson
Senior Developer
Side Effects Software Inc
Senior Developer
