I use following command to bulid sop samples that come alone with Houdini,
source houdini_setup
cd $HFS/toolkit/samples/SOP
hcustom SOP_Star.C
SOP_Star.so has been succesfully built and located in ~/houdini12.0/dso/
!!!!But when i dive into geometry level and press tab, No Star sop found!!!!
Why???I am using the free edition
Thank you very much!
how to register my sop!
1974 3 0- sunhaohui
- 8 posts
- edward
- 7766 posts
- sunhaohui
- 8 posts
- edward
- 7766 posts
Yes, Apprentice edition can load custom SOPs. I forgot to mention that you should copy SOP_Star.C out to writable directory first (eg. $HOME) before running hcustom.
For gcc 4.4, make sure you installed the gcc4.4 version of Houdini. And of course, make sure you're using the right 32-bit or 64-bit compiler that matches the Houdini install you did.
