I hope some of you guys can give me hint…
I'm just playing around with smoke simulations.
I don't know why, but I can't get the smoke to look smooth (see screenshot or simple hip file at frame 23 or later).
I already tried to
- increase the container's resolution
- lower the volume step size in mantra's parameters
- reduce the whole file to the minimum to isolate the problem
… so far no success.
Cheers
H 12.0.581 Win64
Rendered smoke appears aliased/rastered
1822 2 1- bollili
- 205 posts
- andrewc
- 1002 posts
That looks like a filtering issue. H12 changed the default volume filter from a gaussian to a box filter, which will cause the voxels to be more visible than in the past. On the other hand, it's a lot more efficient and produces sharp renders for high voxel count volumes.
To get a smoother result try changing the “Volume Filter” to “Gaussian” and the “Volume Filter Width” to “1.5” on the geometry object.
Andrew
Andrew
- bollili
- 205 posts
