Morning,
i cant figure out what the problem is but a setup with point instancing and geometry light isn't illuminating my scene. Copy stamp works perfectly though, anybody care to take a look?
Cheers!
eitht.
light instancing not illuminating the scene
2563 5 2- eitht
- 257 posts
- rafaels
- 696 posts
I haven't opened your file, but I once had a setup with point lights being instanced using “fast” mode and didn't work at all. I had to switch to “full” to get some result.
Cheers
Cheers
Toronto - ON
- eitht
- 257 posts
- eitht
- 257 posts
- rafaels
- 696 posts
I was fiddling with your file and found that your ground plane had a weird light mask pattern. I just deleted everything but the “*” and it worked fine…
Brace yourself for render times though!
And make sure you reduce the light intensity before you try to render.
Cheers
Cheers
Toronto - ON
- eitht
- 257 posts
