Soft Radius, no Edge Distance?
   9636   10   4
Hey guys,
When using Edit or Smooth Transform SOPs , we have a Point Connectivity option, but no Edge or Surface Distance. That is, in Max for instance, you can set your falloffs to be not only a volumetric radius, but to only affect a particular threshold of connected points/edges/face on a surface, so on folded surfaces for example you can exclude elements that are within the falloff radius but are “far away” in terms of surface area.
Is there an equivalent to this in Houdini, or does it require a workaround?
Thanks in advance!
Edited by - April 30, 2012 05:56:58
U looking for Soft Tranform?
eitht.
Yeah sorry, I said Smooth Transform whereas I meant Soft Transform.
Here's an example scenario, with a corkscrew - the Soft Radius is affecting all vertices, whereas I only want to affect vertices within a set distance from my group's selection.
Ensure “Ignore Point Connectivity” is OFF.
Thanks Edward, that's the first thing I did (and it is of course the default), however Point Connectivity only checks that the points are connected, which is halfway there - I need to know they're Connected Points, and that they're within N connections of my selection.
In the image below I've drawn a U shape, and selected & moved points 0-3 with Soft Radius turned on and Ignore Edge Connectivity disabled. The Soft Radius is including ALL nearby points that fall within the radius, whereas the behaviour I'm looking for would allow me to also assign a connectivity distance of (in this case) 3 points, or edges, so that only connected points 0-5 along U are being moved - the equivalent of a simple mask, in effect.
Edit: It appears you've come across this same thing before (7 years ago!). No resolution then either… this is a pretty fundamental falloff feature in modelling these days, I'm really surprised the RFE never found it's way into production
http://www.sidefx.com/index.php?option=com_forum&Itemid=172&page=viewtopic&p=22921&sid=20ab56383e6fbf1c14d94563d982df36 [sidefx.com] :roll:
Hey Adam, this seems to work for me using the edit SOP with default settings. Check out this post
http://www.sidefx.com/index.php?option=com_forum&Itemid=172&page=viewtopic&t=5114 [sidefx.com]
Are you using the edit SOP transform manipulator, or the brush?
-G
AdamT
Sorry, I keep forgetting that. ops:
Still hoping one day Sesi will add this, sadly modelling tools aren't getting much love any more. It's all about blowing stuff up :cry:
Simon
+1 ,
imho with few touches ‘here’n'there' a lot of more things could be better .
except the things that cannot be seen , nothing is like it seems .
This really is annoying and needs to be looked at.
RFE submitted
(ID=72902)
Werner Ziemerink
Head of 3D
www.luma.co.za
I implemented this for Houdini before and it's very fast:
https://vimeo.com/137783504 [vimeo.com]
