Hi all,
again a houdini noob question:
Is it possible to render a glasmaterial (I tried the provited glasshader from H12) with Fresnell Alpha? With the Houdini shader I get a complete white alpha!!!
I made an example with Softimage to explain what I mean…
Thank you for your help.
Greets
Nico
GlasMat with Fresnel Alpha?
4770 8 3- nicoM
- 74 posts
- nicoM
- 74 posts
- Erik_JE
- 299 posts
- nicoM
- 74 posts
- nicoM
- 74 posts
- old_school
- 2540 posts
You can drive whatever value you want in to the alpha output channel.
Try appending a Luminance VOP to the Surface Color CF output tab of the surfaceModel VOP and then wire that in to the Af Alpha output inplace of the alpha para/perp logic.
One reason as to why the alpha is rendered solid is that the compositor generally doesn't know how to refract rays through a transparent object but the render engine does so let the renderer do it and set alpha solid to block out background objects.
- zarti
- 330 posts
jeff
.. and set alpha solid to block out background objects.
yes , thats exactly how i deal with ‘glasses’ .
@nicoM : i isolate the whole silhouette with the Alpha value 1 and feed into Opacity whatever ‘color i like’ . usually optimized reflections and refractions are separate passes too . i materialize glasses in post and almost never straight from the 3D render . since it is an expensive procedure i found this workflow best for almost every case .
so , in short , if you want colored Alpha , just use Opacity .
.cheers
except the things that cannot be seen , nothing is like it seems .
- nicoM
- 74 posts
- schyzomaniac
- 69 posts
Hi
I am encountering the same issue at the moment, where I would need black (or shades or grey) in the alpha whenever a ray doesn't hit anything.
Right now I am getting solid white everywhere I have refractions.
This is okay for most of the time when working with backplates. But sometimes I need to put glass-like objects on a background later in comp, and therefore need transparency.
I tried the luminance VOP that Jeff suggested, but it just takes the average of the luminance from C and pipes it into AF, therefore ignoring if the ray continues and hits a solid pixel “behind” a refractive pixel. This introduces transparency where it's not supposed to be.
Any other advises then the ones mentioned above?
cheers,
Daniel
cheers,
Daniel
