I couldnt find any post on the forum about what happened to the old Shatter Sop ???
Has it disapeared for ever? or is it just in my apprentice version ?
I used it a few years ago and I liked the way it worked and as it was not as sophisticated as a voronoi it did things in it's own way whitch I cant reproduce with the voronoy….
Shatter Sop
3015 4 2- NAHASSIA
- 125 posts
- sami.tawil
- 172 posts
- NAHASSIA
- 125 posts
- old_school
- 2540 posts
The Shatter SOP is there along with a bunch of other operators that are deprecated in favour of improved options. It's just hidden from the tab-type menus.
In a Houdini textport pane, type in:
ophide
and you get a long list of operators that have been “hidden” but are still there for backwards compatibility.
To make the Shatter SOP available, type in the Houdini textport:
opunhide Sop shatter
Now you can tab-type add the Shatter SOP to your SOP network.
If you want this all the time, copy/edit a 456.cmd file in your $HOME/houdini12.0 directory to include the opunhide command above so that it is there all the time.
ophide
- NAHASSIA
- 125 posts
