can prman render L-system?
4803 4 1- ykcosmo
- 288 posts
- Dave_ah
- 436 posts
L-SYstem just generates geometry. Just render it like you would any geometry. If you have any doubts, just append ConvertSOP (to Polygons) to the L-System network, and as far as PRMAN or MR3 are concerned , they are rendering polygons.
If you still have problems, just bake out the L-System, into BGEO sequence, with GeometryROP, if its animated. Then reloaded the seuqnce with FileSOP set to display and render. I do this all the time, cause in my case I have had to render with MRFM through Maya, so I had a MEL that would load the OBJ sequence and set Visibility keys for them. Worked great provided Maya did not run out of ram.
- ykcosmo
- 288 posts
- aracid
- 154 posts
hey ykcosmo
about ur l-system, if u adding leaves or whatever, then u should group them before they go into ur l-sys, and then when u can add a shader sop for the leaves after the lsys, just use the name of the group of the leave before it goes into ur l-sys.
even works once the geom has been converted.
hope this helps
all the best
aracid
hope this helps
all the best
aracid
- ykcosmo
- 288 posts
