Hi, Guys. I'm trying to make active objects by attribtransfer. But it doesn't work :shock:
I was trying to use RBD keyframe active and Active value. But both of them didn't work
I want to make red point objects as active objects and keeping position other objects.
I'm attaching my file.
I'll wait great answers from advanced users.
Thanks~!
2569 3 0- lwbi
- 9 posts
- tamte
- 8568 posts
you need to set operation in activevalue1 to Set Always
and since you are changing active value just on group you need to start with inactive objects so in box_object1 uncheck Create Active Objects
it should work then
or
you can use your expression directly in activevalue1 node avoiding creating group (see the file), and this will set active value for each object on every timestep so it may provide you greater control since you will be able to deactivate any piece again if you want
it should work then
or
FX Supervisor
Method Studios, NY
FX Supervisor
Method Studios, NY
- lwbi
- 9 posts
Thanks a lot~! It works perfectly~!! I have a question of this file.
You putted a point expression into activevalue1 node's activation parameter. Why does it work? I thought the activation parameter only works with 1 or 0 value. The point expression will return red points. Could you explain of it?
Thanks.
Thanks.
tamte
it should work then
or
- tamte
- 8568 posts
