I searched the forum but could not find the answer.
I have two boxes intersecting, used cookie on them and now i have two objects making one box , fractured the small one and used activevalue node on the fractures with colors to turn them to active when a spheres area intesects with the scatter points…
Then I turned this into fracturedRBD and the rest of the cube to passive it works all nice objects are popping when turn active but I am half way there.
The problem is I have the passive box animated, but they dont move with the passive box, I tried parenting the RBD obj to Passive box at object level, still no good.
Anyone has an answer for this, here is the scene file///
Parenting RBD to Passive and turning active from Color Point
2219 1 1- tricecold
- 260 posts
Head of CG @ MPC
CG Supervisor/ Sr. FX TD /
www.timucinozger.com
- tricecold
- 260 posts
it was the only button i Didnt click which turns out to be Use Deforming Geometry
Head of CG @ MPC
