hello,
I'm stuck on a problem and not sure if pops is the solution.
I am driving particle velocity via popVop to a goal. When the particle gets within 10 units of the goal I want the particles to be advected by a fluid for say 20 frames and then continue on to the goal. I was thinking of putting the particles in a group for 20 frames to get the fluid advection.
Not sure how to do this?
Is there a way to put particles in a group for x frames?
Tia
Put particle in group for x frames?
2944 7 0- l3g3nd
- 33 posts
- tamte
- 8554 posts
you can create and attribute like start_frame make default very low like -1e9
then when particle triggers the condition set it to current floating frame
from that point don't allow the start_frame to update
(so condition would be like: distance to goal < 10 and start_frame == -1e9, in this case it will update only once since second part of the condition will not be true after first update)
then just create non-persistent group with the condition like:
$FF < ($START_FRAME + 20)
this will be true only for 20 frames since start_frame was set and so the point will be in group just 20 frames
use that group for your advection
there is plenty of other ways how you can do this
and if you were looking for Remove From Group VOP, there is removegroup() vex function you can use to remove particles from groups, so just use it in Inline VOP for that purpose.
FX Supervisor
Method Studios, NY
FX Supervisor
Method Studios, NY
- l3g3nd
- 33 posts
- tamte
- 8554 posts
it doesn't have to be so small, but because of the condition
$FF < ( $START_FRAME + n )
you certainly want it smaler than -n, othervise the initial value would satisfy that condition on early frames if you are starting from 0 or 1
so making it extremely small you are simply avoiding those problems when n is an user defined variable
and it's easier to realise that that's an extreme
if you have put -100 in there, anybody can wonder why is -100 in there, if it's extremely small number, it's kind of logical
FX Supervisor
Method Studios, NY
FX Supervisor
Method Studios, NY
- l3g3nd
- 33 posts
- l3g3nd
- 33 posts
- tamte
- 8554 posts
you may find some examples on forums
but it's very simple, usually you don't care about include files
just plug inputs to inline vop
setup your output names and types if you want some outputs
then just write inline code in normal VEX, refering to inputs and outputs as variables starting with $
here is simple example including remove group, using some inputs and outputs and internal variables, but really just for you to see the usage, as a tool it makes no sense and notice that internally defined variables are used without $, like in normal VEX
FX Supervisor
Method Studios, NY
FX Supervisor
Method Studios, NY
- l3g3nd
- 33 posts
