Dear teacher
Houdini how to set the time slider precision. For example, a ball speed quickly, emitting particles increases Oversampling cannot achieve smooth particle effects. So I want to try to calculate the 1.1F 1.2F… Position thereby emitting particles. Smoothing effect. Thank you
Particle sample。
1901 2 1- chinacat
- 48 posts
- old_school
- 2540 posts
If you set the particle oversampling to say 10 you would then be evaluating the POP network 10 times per frame.
To scrub the viewport to see subframes, you need to open the Playback Options dialog.
If you set oversampling to 10 or ten steps per frame, set the Step to 1/10 or 0.1.
Now when you scrub the playbar, you will be scrubbing in integer steps of 1/10 frames.
- chinacat
- 48 posts
