Hello every one and Happy New Year!
I am having a problem with RBD Objects laid on a surface. When this surface is rising like an elevator (keyframe), the RBDs don't collide and so don't follow the surface although the surface is pretty slow. If the surface is not rising, the RBDs collide.
I increased the Sub Steps in the dopnet to 8 but the problem remains. I increased the offset surface too in the RBD Object of the surface but it only offseted the problem.
RBD collision with a rising object
2933 5 0- arthurG
- 6 posts
- rweston
- 30 posts
- tamte
- 8579 posts
just a guess. but
if you are animating the surface on sop level, it is considered deformation and you need to check Use Deforming Geometry on Static Object DOP (or RBD)
however, if it is just simple transform (no actual deformation) it is much better(faster) to animate your object on object level and check Use Object transform checkbox
FX Supervisor
Method Studios, NY
FX Supervisor
Method Studios, NY
- arthurG
- 6 posts
- tamte
- 8579 posts
you have few options
either use bullet solver
or for RBD solver check either
Use Point Velocity For Collisions
or
Use Volume Velocity For Collisions
or both
but that's only because you have deforming geometry
so if you move your transform to object level, everything would be faster and work straight away since it will use rbd velocity for collisions, see the example
or
or both
FX Supervisor
Method Studios, NY
FX Supervisor
Method Studios, NY
- arthurG
- 6 posts
