There are two axes. One is responsible for field.
And the second ?
Pyro 2 shader question.
1661 2 1- kzoper
- 2 posts
- tamte
- 8577 posts
first the field is rescaled into 0-1 range using (Fit Range (Unclamped) and Ramp Interval parameters) if they are used
then X axis represents such rescaled value of the source field
Y axis represents new corresponding value which will become the result
so if X is 0.5 while Y is 1 it means that where rescaled source was 0.5 output value will be 1, it essentially allows you to shape the value using lookup curve over the value of the original field
FX Supervisor
Method Studios, NY
FX Supervisor
Method Studios, NY
- kzoper
- 2 posts
